跳转到主内容
磁盘延迟、并出现extcache.io.writeError和insert_Reject限制_io
544
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
适用场景
  • ONTAP 9
  • 所有采用基于NVMe的闪存的FAS 系统
问题描述
  • Disk 延迟中心延迟增加
cluster01::> qos statistics volume latency show -vserver vserver01 -volume volume01
Workload       ID   Latency   Network   Cluster    Data    Disk   QoS Max   QoS Min    NVRAM    Cloud  FlexCache   SM Sync     VA
-total-        -   24.06ms  104.00us   53.00us  556.00us   23.35ms     0ms     0ms   3.00us     0ms     0ms     0ms     0ms
volume01-wid51230   51230   22.49ms  104.00us   52.00us  526.00us   21.81ms     0ms     0ms   3.00us     0ms     0ms     0ms     0ms
-total-        -   13.60ms  143.00us   60.00us  188.00us   13.21ms     0ms     0ms   2.00us     0ms     0ms     0ms     0ms
volume01-wid51230   51230   13.19ms  143.00us   59.00us  185.00us   12.80ms     0ms     0ms   2.00us     0ms     0ms     0ms     0ms
  • 多个事件
wafl_exempt09: ems.engine.suppressed:debug]: Event 'extCache.io.writeError' suppressed 67626 times in last 601 seconds.
wafl_exempt09: extCache.io.writeError:notice]: WAFL external cache I/O write error: Insertq_save: unable to set up context chain, code 0
  • FlashCache不再插入
cluster01::> node run -node node02 stats show -p flexscale-access
Cache                        Reads    Writes    Disk Reads
Usage   Hit  Meta  Miss Hit Evict Inval Insert Chain Blocks Chain Blocks  Replaced
%   /s   /s   /s  %   /s   /s   /s   /s   /s   /s   /s     /s
45   703   11  39171  1   0   0    0   0    0   0    0    109
45   320   26  37607  0   0   0    0   0    0   0    0     98
45   903   51  38018  2   0   0    0   0    0   0    0    114
  • 重新启动会暂时修复此问题
New to NetApp?
