跳转到主内容
CIFS客户端访问缓慢,FPolicy反复断开
523
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
适用于
  • ONTAP
  • CIFS
  • FPolicy
问题描述
  • 启用 FPolicy 时 CIFS 客户端较慢
  • PA 观察到高延迟
  • 禁用 FPolicy 解决 CIFS 客户端较慢问题
  • EMS 显示以下错误:
Mon Jan 04 12:09:45 EST [example: fpolicy: fpolicy.server.connectError:error]: Node failed to establish a connection with the FPolicy server '10.1.1.101' (reason: 'Connection to FPolicy server is broken(EPIPE) received.').
Mon Jan 04 12:09:45 EST [example: fpolicy: fpolicy.server.disconnect:warning]: Connection to the Fpolicy server '10.1.1.101' is broken ( reason: 'FPolicy server is removed from external engine.' ).
Mon Jan 04 13:06:11 EST [example: fpolicy: fpolicy.server.disconnect:warning]: Connection to the Fpolicy server '10.1.1.101' is broken ( reason: 'FPolicy server is removed from external engine.' ).
Mon Jan 04 13:06:36 EST [example: fpolicy: fpolicy.server.connectError:error]: Node failed to establish a connection with the FPolicy server '10.1.1.101' (reason: 'Select Timed out.').
New to NetApp?
