跳转到主内容
CONAP-311454:由于客户端流量较高、导致延迟和减慢
287
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
问题描述
  • The following EMS message is seen and high utilization is seen on a network context:
Mon Sep 09 10:23:29 +0000 [node1: kernel: net_cg_utilThresholdExceed_1:notice]: params: {'connection_group': '20', 'current_utilization': '98', 'configured_threshold': '95'} Cluster::> set -privilege diagnostic; statistics show -object nwk_ctx -counter utilization -raw -tab -filter "utilization>30" -node node1; set -privilege admin node1: nwk_ctx: 10/22/2024 10:06:06 instance name utilization -------- ----------- ctx_09 98
  • Latency is seen which is high from users, as shown in the Network column of the below output:
Cluster::> qos statistics volume latency show -vserver svm1 -volume vol1 Workload ID Latency Network Cluster Data Disk QoS Max QoS Min NVRAM Cloud FlexCache SM Sync VA AVSCAN --------------- ------ ---------- ---------- ---------- ---------- ---------- ---------- ---------- ---------- ---------- ---------- ---------- ---------- ---------- -total- - 744.00us 328.00us 0ms 392.00us 4.00us 0ms 0ms 20.00us 0ms 0ms 0ms 0ms 0ms vol1-wid12503 12503 93.25ms 93.18ms 0ms 69.00us 0ms 0ms 0ms 1.00us 0ms 0ms 0ms 0ms 0ms
  • ifstat -a -v from the node shell shows the RSS utilization (9.14.1 or higher) on one Connection Group by a higher value of packets:
Cluster::> run -node node1 ifstat -a -v ... Queue 7 CG ID: 8 | Rx packets: 361m | Rx bytes: 1065g Tx packets: 472m | Tx bytes: 4039g ... Queue 8 CG ID: 9 | Rx packets: 35967m | Rx bytes: 50080g <---higher amount of packets Tx packets: 3206m | Tx bytes: 21002g ... Queue 9 CG ID: 10 | Rx packets: 1063m | Rx bytes: 3071g Tx packets: 426m | Tx bytes: 5950g
New to NetApp?
