跳转到主内容
为什么某些NIC电缆断开测试不会生成ASUP?
31
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • AutoSupport (ASUP)
问题解答
由于ONTAP上的默认设置、在网络缆线断开测试期间、不会为某些NIC断开连接生成ASUP。
  • 观察到的行为:
  1. 服务(数据) NIC电缆断开连接 -未生成ASUP消息。
EMS日志:
[node: intr: netif.linkDown:info]: Ethernet e2a: Link down, check cable.
[node: intr: net.ifgrp.lacp.link.inactive:error]: ifgrp a0a, port e2a has transitioned to an inactive state. The interface group is in a degraded state.
[node: vifmgr: vifmgr.portdown:notice]: A link down event was received on node node, port e2a.
  1. 集群互连NIC电缆断开连接 -不生成ASUP消息。
EMS日志:
[node: intr: netif.linkDown:info]: Ethernet e1a: Link down, check cable.
[node: vifmgr: vifmgr.portdown:notice]: A link down event was received on node node, port e1a.
[node: vifmgr: vifmgr.clus.linkdown:EMERGENCY]: The cluster port e1a on node node has gone down unexpectedly.
[node: vifmgr: vifmgr.lifmoved.linkdown:notice]: LIF node_clus2 (on virtual server 4294967293), IP address 169.254.254.83, is being moved to node node, port e0a.
[node: vifmgr: vifmgr.reach.noreach:notice]: Network port e1a on node node cannot reach its expected broadcast domain Cluster:Cluster. No other broadcast domains appear to be reachable from this port.
  1. HA互连NIC电缆断开连接— 生成ASUP消息"HA互连已关闭"。
EMS日志:
[node: statd: ic.HAInterconnectDown:error]: HA interconnect: Interconnect down for 2 minutes: link0 down
[node: statd: callhome.hainterconnect.down:alert]: Call home for HA INTERCONNECT DOWN due to link0 down.
  1. 磁盘架连接NIC电缆断开连接-生成ASUP消息"磁盘冗余失败"。
EMS日志:
[node: intr: netif.linkDown:info]: Ethernet e4a-30: Link down, check cable.
[node: intr: nvmeof.timeout:notice]: Timeout on subnqn nqn.2014-08.org.nvmexpress.discovery, controller ID 9, qpair ID 0, sequence number 3704.
[node: intr: nvmeof.timeout:notice]: Timeout on subnqn nqn.2014-08.org.nvmexpress:1b96:1b96:241163800956:X4032WCOFB15TNVE, controller ID 9, qpair ID 0, sequence number 2017.
[node: intr: nvmeof.timeout:notice]: Timeout on subnqn nqn.2014-08.org.nvmexpress:1b96:1b96:241025800131:X4032WCOFB15TNVE, controller ID 9, qpair ID 0, sequence number 2066.
[node: dsa_disc: callhome.dsk.redun.fault:error]: Call home for DISK REDUNDANCY FAILED.
  • 原因:
    • 断开HA互连NIC磁盘架NIC连接后 、会报告"hainterconnect.down "和"dsk.redun.fault "被定义为发送ASUP、如下所示:
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *hainterconnect.down*
node     autosupport-message to    noteto
ontap914-01 hainterconnect.down enabled enabled
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *dsk.redun*
ontap914-01 dsk.redun.fault    enabled enabled
  • 但是、断开 服务(数据) NIC 集群互连NIC 连接会报告 netif.linkDown 和 vifmgr.portdown  等未定义为发送ASUP:
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *net*
ontap914-01 clus.net.degraded   enabled enabled
ontap914-01 mcc.network.stats   disabled disabled
ontap914-01 netif.fatal.error   enabled enabled
ontap914-01 netif.init.failed   enabled enabled
ontap914-01 netif.uncorEccError enabled enabled
ontap914-01 netinet.dup.clustIP enabled enabled
6 entries were displayed.
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *vifmgr*
There are no entries matching your query.
追加信息
其他信息文本
