跳转到主内容
卷效率开始失败、并显示错误"未启用数据压缩"。使用选项-a和-b无效
148
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>SIS</a><a>TSS</a>
Last Updated:
适用场景
  • ONTAP 9.8 及更高版本
  • 存储效率
  • 温度敏感型存储效率( TSSE )
问题描述
尝试重新扫描卷以节省效率时、包括快照和/或共享块、此时会报告以下错误:
cluster01::> set -privilege advanced
cluster01::*> vol efficiency start -volume vol1 -scan-old-data true -snapshot-blocks true
Warning: This operation scans all of the data in volume "vol1" of Vserver "svm1". It might take a significant time, and degrade performance during that time.
     Use of "-snapshot-blocks|-b" option can increase space usage as data which is part of Snapshot will be compressed.
Do you want to continue? {y|n}: y
Error: command failed: Failed to start efficiency on volume "vol1" of Vserver "svm1": Compression is not enabled. Use of options -a and -b is not valid.
cluster01::*>
New to NetApp?
  • 这篇文章对您有帮助吗?
