跳转到主内容
由于缺少MDV_CRS卷、无法创建卷
71
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
适用场景
ONTAP 9
问题描述
  • 由于缺少MDV_CRS卷、无法对系统进行任何修改
  • 创建卷失败并显示错误:
Failed to create the volume on node "node_name". Reason: The MetroCluster or Vserver DR Configuration Replication Service is recovering. Issue the "metrocluster check config-replication show -instance" command or the "snapmirror config-replication status show" command and follow its guidance. If there is no guidance, wait a few minutes and then try the command again.
  • 在SnapMirror目标集群上、SnapMirror关系不存在、但源正在尝试更新不存在的MDV_CRS
  • snapmirror config-replication status show 报告错误:
::*> snapmirror config-replication status show
                Enabled: true
                Running: false
         Storage Status: warning
         Storage In Use: Unavailable
        Storage Remarks: Unable to allocate resources due to error Unable to determine a suitable aggregate to create the Cluster Persistent Storage volume
        Vserver Streams: warning
New to NetApp?
