跳转到主内容
SyncMirror 错误:当前磁盘池分配不能保证使用 SyncMirror 镜像的聚合的故障隔离
16
Visibility:
Internal
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用于
  • 本地同步镜像
  • 高级磁盘分区( ADP )
问题
本地 SyncMirror 创建失败并出现错误。
aggr mirror -aggregate <aggregate> -mirror-partitionlist <partition_list> -simulate true
Error: command failed: Aggregate mirroring would fail for aggregate "<aggregate>" on node "<node>". Reason: Current disk pool assignments do not guarantee fault isolation for aggregates mirrored with SyncMirror. Other disks in the loop are in a different pool than disks: "disk_id", "disk_id". Use "disk show -v" to view and "disk assign" to change the disk pool assignments.
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
