跳转到主内容
删除单个磁盘架后、存储故障转移输出会显示HA节点之间的差异
55
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • FAS/AFA系统
问题描述
  • 在FAS或AFF系统中、 删除单个磁盘架时、storage failover show 在HA节点中显示的输出不同。
    • 从 节点01中的SAS端口0a、5b上拔下缆线时、它会显示:
      ::> storage failover show
                      Takeover
      Node       Partner     Possible State Description
      Node-01       Node-02       -     Kernel loaded
      Node-02       Node-01       false   In takeover
    • 从 节点-02中的SAS端口0c、5d上拔下缆线时、它会显示:
                      Takeover
      Node-01     Node-02     false   Normal giveback not possible:
                          partner missing file system disks
      Node-02     Node-01     -     Waiting for giveback
  • 正常情况下的系统配置:
    • 节点01:
      • SYSCONFIG-A:
        slot 0: SAS Host Adapter 0a (Broadcom SAS3616W rev. 2, SAS, <UP>)
           01.23: NETAPP   X371_S164A960ATE NA54 915.4GB 520B/sect (S5xxxxxxxxxx)
           Shelf 1: DS224-12  Firmware rev. IOM12B A: 0141  IOM12B B: 0141
        slot 5: SAS Host Adapter 5b (Broadcom SAS3616W rev. 2, SAS, <UP>)
      •  STORAGE-FAILOVER.XML:
Node   Node-01
Partner Name   Node-02
Local Mailbox Disks   1.1.12.P3, 1.1.13.P3, 1.1.14.P3
Partner Mailbox Disks   1.1.0.P3, 1.1.1.P3, 1.1.2.P3
SYSCONFIG-R
聚合aggr0_Node-01 (联机、RAID-DP、快速置零)(块校验和)
  Plex /aggr0_Node-01/plex0 (online, normal, active, pool0)
   RAID group /aggr0_Node-01/plex0/rg0 (normal, block checksums)
    RAID Disk   Device     HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)   Phys (MB/blks)
    dparity    0a.01.12P3   0a   1   12  SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    parity     5b.01.13P3   5b   1   13  SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      0a.01.22P3   0a   1   22  SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      5b.01.23P3   5b   1   23  SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      0c.11.12P3   0c   11  12  SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      5d.11.13P3   5d   11  13  SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      0c.11.20P3   0c   11  20  SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      5d.11.21P3   5d   11  21  SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    • 节点-02:
      • SYSCONFIG-A:
        slot 0: SAS Host Adapter 0c (Broadcom SAS3616W rev. 2, SAS, <UP>)
           11.23: NETAPP   X371_S164A960ATE NA54 915.4GB 520B/sect (S5xxxxxxxxxx)
           Shelf 11: DS224-12  Firmware rev. IOM12B A: 0141  IOM12B B: 0141
        slot 5: SAS Host Adapter 5d (Broadcom SAS3616W rev. 2, SAS, <UP>)
        Node   Node-02
        Partner Name   Node-01
        Local Mailbox Disks   1.1.0.P3, 1.1.1.P3, 1.1.2.P3
        Partner Mailbox Disks   1.1.12.P3, 1.1.13.P3, 1.1.14.P3
      • SYSCONFIG-R:
Aggregate aggr0_Node-02 (online, raid_dp, fast zeroed) (block checksums)
  Plex /aggr0_Node-02/plex0 (online, normal, active, pool0)
   RAID group /aggr0_Node-02/plex0/rg0 (normal, block checksums)
    dparity    0a.01.0P3   0a   1   0   SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    parity     5b.01.1P3   5b   1   1   SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      0a.01.10P3   0a   1   10  SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      5b.01.11P3   5b   1   11  SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      0c.11.0P3   0c   11  0   SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      5d.11.1P3   5d   11  1   SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      0c.11.8P3   0c   11  8   SA:B   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
    data      5d.11.9P3   5d   11  9   SA:A   0   SSD   N/A 9594/19650048    9602/19666432 (fast zeroed)
New to NetApp?
  • 这篇文章对您有帮助吗?
