跳转到主内容
意外停电或 HeadSwap 后需要根卷恢复
342
Visibility:
Votes:
4
Category:
ontap-9
Specialty:
core
Last Updated:
适用于
  • ONTAP 9
  • 因停电而关闭
问题
  • 意外停电后,ONTAP 启动并显示以下消息:
The contents of the root volume may have changed and the local management configuration may be inconsistent and/or the local management databases may be out of sync with the replicated databases. This node is not fully operational.
Contact support personnel for the root volume recovery procedures.
[cluster:callhome.root.vol.recovery.reqd:EMERGENCY]: Call home for ROOT VOLUME NOT WORKING PROPERLY: RECOVERY REQUIRED.
Internal error: Cannot open corrupt replicated database. Automatic recovery attempt has failed or is disabled. Check the event logs for details. This node is not fully operational. Contact support personnel for the root volume recovery procedures.
  • 服务不会在受影响的节点上联机
New to NetApp?
