跳转到主内容
ONTAP 升级失败 - 启用 SSL FIPS 模式时不支持 "aes128-gcm" 和 "aes256-gcm"
165
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用于
  • 启用 FIPS 的 ONTAP 升级
问题
  • 检查更新进度
Cluster::> set diag
Cluster::*> cluster image show-update-progress
Estimated         Elapsed
Update Phase         Status                   Duration        Duration
Pre-update checks    completed                00:10:00        00:00:04
Data ONTAP updates   paused-on-error          01:17:00        21:17:45
  • 查看升级期间失败的任务
 Cluster::> set advanced
Cluster::*>system node upgrade-revert show -node Clustern1
Node: Clustern1                                    Status: aborted
Status Message: The upgrade aborted. Contact support personnel for the upgrade repair procedure.
Vers Phase      Status   Upgrade Phase Status Message
700  pre-root   applied  No upgrade is required for this phase.
700  pre-apps   applied  Upgrade successful.
700  post-apps  aborted  Cipher(s) "aes128-gcm" and "aes256-gcm" are not supported when SSL FIPS mode is enabled.
3 entries were displayed.
Cluster::*>system node upgrade-revert show -instance
Node         Vers Phase     ID  Proc   Status     Description
Clustern1  600 post-apps 637 mgwd   aborted    sshd config Maxauthtries Upgrade Revert Task
New to NetApp?
