跳转到主内容
在FlexVol volume上启用二级数据压缩时出错
109
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2010034571</a>
Last Updated:
适用场景
ONTAP 9
问题描述
尝试在FlexVol volume上启用二级压缩时收到错误:
::>volume efficiency modify -vserver vs1 -volume vol1 -compression true -compression-type secondary
"Error: command failed: Failed to modify efficiency configuration for volume "vol1" of Vserver "vs1": Failed to set compression type and application I/O size on the volume. Switching between compression type or application I/O size is allowed only after undoing the compression savings on the volume."
New to NetApp?
