升级前后验证检查无法在磁盘架和传感器上执行
适用于
- ONTAP 9
- 服务处理器 (SP)
- 基板管理控制器(BMC)
- SP API 服务
- ANDU 升级验证
- 更新前检查
- 架子和传感器检查
问题描述
- 验证 ONTAP 升级时出现错误消息:
::> cluster image show-update-progress
Estimated Elapsed
Update Phase Status Duration Duration
Pre-update checks failed 00:10:00 00:04:21
Details:
Pre-update Check Status Error-Action
Shelves and Sensors Error Error: Validation check failed to
check execute properly.
Action: If the problem persists after
retrying, delete the package and
download again
- 也可能会看到有关 CPU 利用率的错误:
Action: Ensure CPU utilization is
less than 50% by running the "node
run -node <nodenames> -command
sysstat -c 10 3" command and then try
the validation again using the
"cluster image validate" command. If
the problem persists after retrying,
contact technical support for
assistance.
- 接管/交还已发放的节点无法解决此问题。
