跳转到主内容
移动卷后、moved_paral_temp卷将保留、无法删除
37
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • Cloud Volumes ONTAP (CVO)
  • 卷移动操作
  • FlexClone父卷
问题描述
  • 执行卷移动操作后、存在一个名为moved_parent_temp__xxxxx 的脱机TMP卷、无法将其删除:
ontap913::*> volume move start -vserver test2 -volume voltest2 -destination-aggregate agg21 -cutover-action wait
Warning: You are about to move a volume that has clones. The system will leave a temporary copy on the source aggregate until you split or delete these clones. Do you want to
     proceed? {y|n}: y
ontap913::> volume show
Vserver Volume    Aggregate   State    Type    Size  Available Used%
test2    moved_parent_temp__1175__4364__voltest2
            aggr22     offline   TMP     200MB      -    -
test2    voltest2    agg21     online    RW     200MB   88.87MB   53%
test2    voltest2_clone
            aggr22     online    RW     200MB   189.7MB   0%
  • 已删除与父卷关联的FlexClone卷
ontap913::*> vol delete -vserver test2 -volume  moved_parent_temp__1175__4364__voltest2 -force true
[Job 4442] Job is queued: Delete moved_parent_temp__1175__4364__voltest2.
Error: command failed: [Job 4442] Job failed: Failed to delete volume "moved_parent_temp__1175__4364__voltest2" in Vserver "test2"because it has one or more clones. Only the cluster administrator can delete the clones associated with this volume.
New to NetApp?
