跳转到主内容
断电后、FlexGroup上的快照丢失、未尝试手动删除
77
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • 包含2个以上节点的ONTAP 9集群
  • FlexGroup与跨越一个HA对的成分卷一起使用
  • FlexGroup快照
问题描述
  • 一个HA对中的两个节点:
    • 拥有同一FlexGroup的成分卷。
    • 在未完全关闭的情况下意外同时重新启动(例如、由于多磁盘崩溃或断电)。
    • 同时重新启动。
  • 重新启动后、一个或多个FlexGroup快照将完全丢失、 -snapshot showSize Total% Used% 如果只有部分成分卷丢失了相应的FlexGroup快照、则会从下显示:
::>set adv
Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel.Do you want to continue? {y|n}: y
::*>vol show -vserver svm1 -volume MyFlexgroup1 -fields is-flexgroup
vserver volume       is-flexgroup
svm1    MyFlexgroup1 true
::*>volume snapshot show -vserver svm1 -volume MyFlexgroup1
        ---Blocks---
Vserver  Volume   Snapshot                                  Size Total% Used%
svm1     MyFlexgroup1
                  MySnapshot1                             -         -   -
                  hourly.2024-03-11_0905                   360KB     0%   36%
2 entries were displayed.
1 entry was acted on.
::*>node run -node MyCluster-01 -command snap status MyFlexgroup1__0001
Node: MyCluster-01
Volume MyFlexgroup1__0001
snapid  status     date           ownblks release fsRev name
  2     complete   Mar 11 09:05        47     9.7 35092 hourly.2024-03-11_0905
 1     complete   Mar 11 09:00        47     9.7 35092 MySnapshot1
::*>node run -node MyCluster-02 -command snap status MyFlexgroup1__0002
Node: MyCluster-02
Volume MyFlexgroup1__0002
注意: 成分卷MyFlexgroup1__0002上缺少MySnapshot1
::*>snapshot show -vserver svm1 -volume MyFlexgroup1 -snapshot MySnapshot1 -fields state
vserver volume       snapshot    state
svm1    MyFlexgroup1 MySnapshot1 unknown
  • 如果删除的快照过多、则受影响节点可能会在重新启动后发生崩溃:
Panic_Message: timeout table full in SK process snap_lopri_work on release 9.11.1P8
注意: 这只是一个副作用、根据缺陷 CONVA-20171进行了跟踪
New to NetApp?
