跳转到主内容
是否可以从FlexGroup 的转换前快照创建克隆
4
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
ONTAP
FlexGroup
Flex 克隆
问题解答
目标卷将灵活卷转换为FlexGroup 后、所有现有快照都将标记为预转换、不能用于创建克隆。
追加信息
尝试时将显示以下错误:
cluster2::*> volume clone create -flexclone clonevol -type RW -parent-vserver svm1 -parent-volume siva -foreground true -parent-snapshot snap1
Error: command failed: Cannot create clone from Snapshot copy "snap1" because the Snapshot copy was created when volume "siva" in Vserver "svm1" was a FlexVol.
cluster2::*>
