跳转到主内容
Flash Pool或Storage Pool聚合的每周spares_low错误
22
Visibility:
Votes:
0
Category:
fas-systems<a>存储池</a><a>Flash Pool</a><a>2008844517</a><a>spare_low</a>
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9.7 或更高版本
  • Flash Pool/Storage Pool聚合(混合聚合)
问题描述
  • 将 ONTAP 升级到 9.7P14 后,系统每周触发一次警告:
Fri Jun 25 11:53:00 +0200 [node-01: monitor: monitor.globalStatus.nonCritical:error]: There are no enough spare disks.
Fri Jun 25 12:00:00 +0200 [node-01: config_thread: callhome.spares.low:error]: Call home for SPARES_LOW
  • 无驱动器故障。
  • 没有向任何现有混合聚合添加其他驱动器。
  • 混合聚合使用 RAID4 组:
Aggregate data_aggr (online, mixed_raid_type, hybrid) (block checksums)
  Plex /data_aggr/plex0 (online, normal, active, pool0)
   RAID group /data_aggr/plex0/rg0 (normal, block checksums, raid_dp)
   RAID group /data_aggr/plex0/rg1 (normal, block checksums, raid4)
    RAID Disk   Device     HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)   Phys (MB/blks)
    parity     0b.00.1P1   0b   0   1   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
    data      0b.00.3P1   0b   0   3   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
   RAID group /data_aggr/plex0/rg2 (normal, block checksums, raid4)
    parity     0b.00.1P2   0b   0   1   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
    data      0b.00.3P2   0b   0   3   SA:A   0   SSD   N/A 228853/468690944  228861/468707328
  • 没有可用于带有 SSD的RAID组的备用驱动器
New to NetApp?
