速度修改失败、因为它无法修改大于100MB的速度
适用场景
ONTAP 9.12.
问题描述
无法将管理速度修改为大于100 MB、即使它是端口支持的速度也是如此。
和只
auto 10 100
能在命令中显示。示例:
NodeA::> network port modify -node NodeA -port e0e -speed-admin 10000
Warning: This command will cause a several second interruption of service on
this network port.
Do you want to continue? {y|n}: y
Error: command failed: Port speed settings greater than 100Mb are not supported.
NodeA::> network port modify -node tcldhxcc3301a -port e0e -speed-admin
auto 10 100
