跳转到主内容
system node power show失败、由于VLAN标记、节点上的服务处理器无法访问
90
Visibility:
Votes:
0
Category:
aff-series<a>2009228160</a>
Specialty:
hw
Last Updated:
适用场景
  • BMC
  • service-processor API-service
  • 集群管理LIF不在专用管理端口e0M中
问题描述
  • 发出system node power show""时出错。
示例:
::> system node power show
Node        Status
node_name-01   on
Error: The Service Processor on node "node_name-02" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again.
node_name-02   -
  • EMS/事件错误消息。
示例:
[node_name-01: servprocd: splog.sp.not.accessible:error]: The SP on the remote node (node_name-02) is not accessible because of The Service Processor on node "node_name-02" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal, check that network ports are configured correctly and are functional (up). Then, try the command again..
  • SP-MGMT-MLOG-TXT.GZ AutoSupport部分超时错误。
示例:
[kern_servprocd:info:7038] Thrift: Mon Jul 11 14:43:50 2022 TSocket::open() timed out <Host: 123.123.123.123 Port: 50000>
[kern_servprocd:info:7038] ERR: Servprocd::CLI: system_power_status_worker : TTX ERROR: 1 (open() timed out)
  • system node power show 当连接到节点管理LIF而不是集群管理LIF时、命令有效。
  • storage failover hwassist show 报告活动和运行状况良好的输出
  • 命令 system service-processor api-service show 显示已启用、但使用内部证书。
  • 与节点管理LIF相比、集群管理LIF的IP地址具有不同的子网掩码。
示例:
Cluster1::> net int show -role *mgmt*
       Logical   Status    Network       Current     Current Is
Vserver    Interface  Admin/Oper Address/Mask     Node      Port   Home
Cluster1
       cluster_mgmt up/up   10.XXX.XXX.130/23   Node-1     e2a   false
         node1_mgmt up/up      10.XXX.XXX.128/24     Node-1      e2a     true
         node2_mgmt up/up      10.XXX.XXX.139/24     Node-2      e0M     true
New to NetApp?
