跳转到主内容
系统启动失败,出现"System DIMM configuration is not supported"
219
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用于
  • FAS8200
  • FAS8020
  • FAS2620
  • AFF8080
  • FAS8300
  • AFF A400
  • FAS8700
问题
存储系统无法启动并自行停止。存储系统启动时,将报告以下错误消息:
示例:
System DIMM configuration is not supported on FAS8200
Please check the DIMM placement on SLOT-1 SLOT-2 ...
Halting...
示例:
DIMM missing in slot DIMM-2
DIMM missing in slot DIMM-3
System DIMM configuration is not supported by FAS8020
示例:
System DIMM configuration is not supported on FAS2620
Please check the DIMM placement on SLOT-1 ...
Halting...
New to NetApp?
