跳转到主内容
在 DS2246 磁盘架上观察到温度传感器 1 温度过低警告
186
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
HW
Last Updated:
适用场景
DS2246 磁盘架
问题描述
  • 系统正在报告多个警告
Tue Jun 30 09:17:09 GMT [node-01: dsa_worker4: ses.status.temperatureError:critical]: DS2246 shelf 2 on channel 0a temperature error for Temperature sensor 1: critical status; undertemperature failure. Current temperature: 4 C (32 F).
  • 可以使用以下命令观察问题描述
Cluster::> system node run -node <node name> -command storage show fault
Enclosure Status: non-critical
Channel: 0a
Shelf: 2
Shelf Type: DS2246
Product Serial Number: XXXXXXXXXX
Module Type: IOM6
Temperature Sensors:
Element Status Status Bytes Status Descriptions
1: NONCRITICAL 03,00,18,01 UT WARNING
2: OK 01,00,23,00
3: OK 01,00,27,00
4: OK 01,00,3E,00
5: OK 01,00,26,00
6: OK 01,00,3E,00
7: OK 01,00,28,00
8: OK 01,00,28,00
New to NetApp?
