跳转到主内容
FAS8300 系统中意外断电触发接管
117
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用于
FAS8300
问题描述
  • 观察到两个意外的系统重新启动。
  • 在第一次重新启动期间,系统恢复,并且回馈成功。
  • 在第一次重新启动期间,BMC 日志中没有明显的硬件故障信息或死机信息。
  • 控制器报告同时失去了两个电源(PSU1 和 PSU2)的直流电源,导致节点自动重新启动并触发接管。
BMC console log
Entity Presence PSU1_VIN_TYPE_DC | Absent | Asserted
Entity Presence PSU2_VIN_TYPE_DC | Absent | Asserted
System Firmware Progress | Secondary CPU Initialization | Asserted
System Firmware Progress | USB resource configuration | Asserted
System Firmware Progress | PCI resource configuration | Asserted
System Firmware Progress | Video initialization | Asserted
System Firmware Progress | Keyboard controller initialization | Asserted
System Firmware Progress | Hard-disk initialization | Asserted
System Event |  | Asserted
  • 在第二次重新启动期间,即使在电源重新启动后,系统也无法开机(system power off/on)。
  • 系统电源状态仍为"Host power is off"
    通过 BMC 发出的命令(例如 system power on、system console)未得到响应。
BMC Log:
BMC > system power status
Host power is off
BMC > system power off
Current power is off, no action is taken
BMC  system power status
Host power is off
BMC >system power on
BMC > system console
 →Pressing the enter key gives no output.
Host power is off
BMC >
New to NetApp?
