跳转到主内容
在BMC命令行界面中看不到系统关闭和多个传感器信息
38
Visibility:
Votes:
0
Category:
fas-systems<a>2009年23月24日55</a>
Specialty:
HW
Last Updated:
适用场景
FAS500F
问题描述
  • 在node-02中检测到IOM12E模块故障并从node-01接管。
EMS 日志:
</LR>
<LR d="09Jul2022 07:22:00" n="node-01" t="1657318920" id="1655365394/8541" p="0" s="Ok" o="monitor" vf="" type="0" seq="75705">
<monitor_globalStatus_critical_1
     problem="This node has taken over node-02. "/>
</LR>
<LR d="09Jul2022 07:22:11" n="node-01" t="1657318931" id="1655365394/8542" p="3" s="Ok" o="dsa_worker0" vf="" type="0" seq="75706">
<ses_status_electronicsWarn_1
     prodChannel="NS224NSM8E (S/N SHJSGXXXXXXXXXX) shelf 0 on channel 0s"
     typeText="SES electronics"
     electrNumber="2"
     warningMsg="communication error"
     warningText="; enclosure services hardware failed"
     locationText="This element is on the rear of the shelf at the bottom, on shelf module (B)"/>
</LR>
<LR d="09Jul2022 07:22:11" n="node-01" t="1657318931" id="1655365394/8543" p="1" s="Ok" o="dsa_worker0" vf="" type="0" seq="75707">
<ses_status_ModuleError_1
     moduleType="PCI switch"
     typeText="PCI Switch"
     ModuleNumber="2"
     errorMsg="status not available"
     errorText="; status not available"
  • 接管后、从DOWN node-02端的BMC命令行界面IPMI传感器显示为"na"状态、无法启动。
SP最新IPMI:
=================== sensor ==========================
Sensor name    | reading   | unit     | status| lnr     | lcr     | lnc     | unc     | ucr     | unr
PVCCIN_CPU_FD   | na     | Volts    | na  | na    | 0.490    | 0.784    | 2.195    | 2.391    | na
PVCCSA_CPU_FD   | na     | Volts    | na  | na    | 0.297    | 0.396    | 1.485    | 1.683    | na
PVDDQ_AB_FD    | na     | Volts    | na  | na    | 0.488    | 0.799    | 1.482    | 1.697    | na
PVDDQ_CD_FD    | na     | Volts    | na  | na    | 0.488    | 0.799    | 1.482    | 1.697    | na
PVNN_PCH_AFD    | na     | Volts    | na  | na    | 0.268    | 0.474    | 1.175    | 1.216    | na
P0V9_PLX0_F    | na     | Volts    | na  | na    | 0.293    | 0.741    | 1.190    | 1.248    | na
P0V9_PLX1_F    | na     | Volts    | na  | na    | 0.293    | 0.741    | 1.190    | 1.248    | na
P3V_BAT      | na     | Volts    | na  | na    | 2.340    | 2.652    | 3.276    | 3.354    | na
Bat_Dstg_Cycles  | na     | cycles    | na  | na    | 2.000    | 5.000    | na    | na    | na
Bat_Cycle_Cnt   | na     | cycles    | na  | na    | na    | na    | na    | na    | na
Bat_Power_Fault  | na     | discrete   | na  | na    | na    | na    | na    | na    | na
Bat_Dsg_FET_Flt  | na     | discrete   | na  | na    | na    | na    | na    | na    | na
Bat_Chg_FET_Flt  | na     | discrete   | na  | na    | na    | na    | na    | na    | na
Bat_Pack_Invalid | na     | discrete   | na  | na    | na    | na    | na    | na    | na
Bat_Lrn_Active   | na     | discrete   | na  | na    | na    | na    | na    | na    | na
FRU Presence    | na     | discrete   | na  | na    | na    | na    | na    | na    | na
  • 从BMC重新启动受损节点-02、但无法启动。
New to NetApp?
