跳转到主内容
在 NV 电池正在学习周期期间,系统故障 LED 亮起
243
Visibility:
Votes:
0
Category:
aff-series<a>硬件</a><a>NVMEM电池</a><a>服务处理器(SP)</a><a>2008884691</a>
Specialty:
HW
Last Updated:
适用场景
  • A700
  • FAS9000
  • 服务处理器 (SP)
问题描述
  • 在NV电池处于学习周期时、ONTAP 会报告服务事件 Failed reading sensor: 87。
  • 系统故障 LED 亮起。
A700::*> system controller service-event show -instance
Node: A700-02
Service Event ID: 1
Description: Failed reading sensor: 87
Timestamp: Fri Aug 20 03:23:53 2021
Record 124: Fri Aug 20 01:53:36.319800 2021 [IPMI.notice]: f400 | 02 | EVT: 6f08ffff | Bat_Status | Assertion Event, "Learn Cycle"
Record 125: Fri Aug 20 02:49:02.944878 2021 [IPMI.notice]: f500 | c0 | OEM: f9ff7020ff59 | ManufId: 150300 | Undefined
Record 126: Fri Aug 20 03:24:00.265129 2021 [IPMI.notice]: f600 | 02 | EVT: 6f02ffff | PCM_Status | Assertion Event, "Fault"
Record 127: Fri Aug 20 03:24:04.490203 2021 [IPMI.notice]: f700 | 02 | EVT: 6f02ffff | Bat_Status | Assertion Event, "Fault"
Record 128: Fri Aug 20 05:13:48.589136 2021 [IPMI.notice]: f800 | 02 | EVT: ef02ffff | PCM_Status | Deassertion Event, "Fault"
Record 129: Fri Aug 20 05:13:52.483000 2021 [IPMI.notice]: f900 | 02 | EVT: ef02ffff | Bat_Status | Deassertion Event, "Fault"
Record 130: Fri Aug 20 05:49:41.577860 2021 [SP CLI.notice]: admin "log in from Serial Console"
Record 131: Fri Aug 20 05:52:20.645759 2021 [SP CLI.notice]: admin "system battery show "
Record 132: Fri Aug 20 05:54:08.355322 2021 [SP CLI.notice]: admin "system fru show "
Record 133: Fri Aug 20 05:54:17.291095 2021 [SP CLI.notice]: admin "system fru show * "
Record 134: Fri Aug 20 05:54:29.369730 2021 [SP CLI.notice]: admin "system fru list "
Record 135: Fri Aug 20 05:54:40.770936 2021 [SP CLI.notice]: admin "log out"
Record 136: Fri Aug 20 06:58:40.790652 2021 [IPMI.notice]: fa00 | 02 | EVT: ef08ffff | Bat_Status | Deassertion Event, "Learn Cycle
  • NV 电池完成学习周期后,此服务事件将消失。
  • 系统故障 LED 熄灭
This table is currently empty.
New to NetApp?
