跳转到主内容
在 AFF A400/FAS8300/FAS8700 上暂时无法读取或写入启动设备后发生系统中断
1,541
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF A400
  • FAS8300
  • FAS8700
  • 启动设备
问题
启动设备遇到问题的节点将死机或无法启动 ONTAP。
EMS 日志
以下是在这种情况下可能看到的 EMS 日志条目示例。
  • PANIC: g_vfs_done(): rootfs.uzip read error - suspect boot device in process g_up on release 9.7P4 (C) on Tue Aug 11 02:55:33 EDT 2020
  • PANIC: Process mgwd unresponsive for 158 seconds (mgwd startup: "(2139)") in process nodewatchdog
  • PANIC: Process vifmgr unresponsive for 658 seconds in process nodewatchdog on release 9.7P18
启动失败期间的控制台启动消息
以下是在尝试 ONTAP 引导期间可能看到的控制台消息。
Could not load fat://boot0/X86_64/freebsd/image1/kernel:Device not found
ERROR: Error booting OS on: 'boot0' file: fat://boot0/X86_64/freebsd/image1 /kernel (boot0,fat)
PANIC: thread (swi4: clock (0)) on cpu 0 hung for 4001 milliseconds in process swi4: clock (0) on release xxx (C) on ...
ERROR: ATA device failure
Version 2.20.1276. Copyright (C) 2021 American Megatrends, Inc.
BIOS Date: 01/19/2021 15:40:12 Ver: 16.3
Press <DEL> or <ESC> to enter setup.
Press <F7> to enter Boot Menu.
Ready to boot. ERROR:
 [D9] Boot option loading failed
coredump: processing segment 5, at relative offset 340377600
..........(ada0:ahcich2:0:0:0): WRITE_DMA48. ACB: 35 00 98 05 6c 40 04 00 00 00 00 01
(ada0:ahcich2:0:0:0): CAM status: Command timeout
(ada0:ahcich2:0:0:0): Error 5, Retries exhausted
Aborting dump due to I/O error.
coredump: error: dump compressed: i/o error 'coredump failure' on disk boot device
Failed to dump segments matching 0xf3
ERROR: Failure to build endpoint environment variables. Autoboot will be disabled.
Can't find primary boot device u0a.0
Can't find backup boot device u0a.1
New to NetApp?
