跳转到主内容
更换主板后、系统启动失败、并显示"WARNing: 0 disks found (警告:发现0个磁盘)"错误
109
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用场景
  • 更换主板
  • 硬件更新
问题描述
  • 系统无法 启动并反复重新启动、并显示以下错误:
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
2 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Target Adapters found:
0 Fibre Channel Target Adapters found!
2 iSCSI Target Adapters found!
1 Unknown Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
Jan 15 18:49:54 [localhost:cf.fm.noMBDisksOrIc:warning]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
No root volume found.
Jan 15 18:49:55 [localhost:zapi.sf.up.ready:info]: ZAPI: system node stable after startup.
Rebooting... (press ctrl-c during boot to break reboot loop)
Uptime: 1m17s
System rebooting...
  • 即使在完成主板更换操作步骤后、旧主板仍然是磁盘所有者。
*> disk show  -v
Local System ID: 333333333
  DISK       OWNER                    POOL   SERIAL NUMBER         HOME                     DR HOME                CHKSUM
0a.00.8      node-1  (111111111)    Pool0  Y5bxxxxxxxxx          node-1  (111111111)                          Block
0b.00.11     node-1  (111111111)    Pool0  Y5cxxxxxxxxx          node-1  (111111111)                          Block
0a.00.10     node-1  (111111111)    Pool0  Y5dxxxxxxxxx          node-1  (111111111)                          Block
0b.00.3      node-1  (111111111)    Pool0  Y5exxxxxxxxx          node-1  (111111111)                          Block
0b.00.9      node-1  (111111111)    Pool0  Y5fxxxxxxxxx          node-1  (111111111)                          Block
0b.00.5      node-1  (111111111)    Pool0  Y5gxxxxxxxxx          node-1  (111111111)                          Block
New to NetApp?
