跳转到主内容
Storage shelf show -instance 显示空白输出
227
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF A250
  • AFF C250
  • AFF A800
  • AFF C30
  • AFF A70
  • FAS 500f
  • NS224 NSM8E
  • NS224 NSM16E
  • FS4483 PSM3E
问题
对于内部 NVMe 盘架(NS224 NSM8E/NS224 NSM16E/FS4483 PSM3E), storage shelf show -instance 命令对于电源、风扇和温度等项目显示"-",无法获取信息。
::> storage shelf show -instance
      Shelf Name: 1.0
       Stack ID: 1
       Shelf ID: 0
       Shelf UID: ****
     Serial Number: ****
      Module Type: NSM8E
         Model: NS224NSM8E
     Shelf Vendor: NETAPP
      Disk Count: 24
    Connection Type: NVMe
      Shelf State: Online
        Status: Normal
Modules:                      Module is
                 Monitor   Is    Reporting FW Update        Latest   Swap Operational Module
 ID Part No.    ES Serial No.   is Active Master Element   Progress    FW Rev. FW Rev. Count Status    Location
  A 111-04585+A6 7921130***   true    true   true    not-available 0120   -       0 normal    rear of the shelf at the top, on shelf module (A)
  B 111-04585+A6 7921130***   true    false  false    not-available 0120   -       0 normal    rear of the shelf at the bottom, on shelf module (B)
Paths:
                                                       Speed
Controller      Initiator Initiator Side Switch Port Target Side Switch Port   Target Port     TPGN   Gb/s I/O KB/s   IOPS
aff250-rtp-4a    0s     -              0s              ef000000abef0000   40      0     0     0
aff250-rtp-4b    0s     -              0s              ef000000abef0000   40      0     0     0
Power Supply Units:
                           Crest  Power   Reset   PSU        Operational
 ID Type Part#     Serial#      Power Rating   Factor Drawn   Capable Enabled Firmware Status       PSU Location
Voltage Sensors:
   Voltage Operational
 ID    (V) Status          Sensor Location
Current Sensors:
   Current Operational
 ID   (mA) Status          Sensor Location
Fans:
   Speed Operational
 ID  (RPM) Status          Fan Location
Temperature:
         -- Thresholds °C --
   Temp Is     Low  Low High High Operational
 ID  °C Ambient Crit Warn Crit Warn Status        Sensor Location
DIMM:
 ID Mod Type Size Speed   Status     Location
Boot Devices:
 ID Mod Type      Size Status
Coin Battery:
     Voltage
 ID Mod   (mV) Status
SAS Ports:
                    -- Port Speeds Gb/s -- Power  Port
Phy # IOM Port Type WWPN        Operational Negotiated Status Status
FC Ports:
        Port
 ID Port Type Status
PCIe Ports:
           -- Speed (Gb/s) --
Mod  ID Type    Bay Negotiated Maximum Status
 A   0 disk     0     8.0    8.0 ok
 A   1 disk     1     8.0    8.0 ok
 A   2 disk     2     8.0    8.0 ok
New to NetApp?
