跳转到主内容
重新布线后、磁盘架显示不正确
24
Visibility:
Votes:
0
Category:
fas-systems<a>2008898230</a><a>进行翻译</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS8700
  • ONTAP 9.7P9
  • DS2246磁盘架
  • I/O模块(IOM)固件191
问题描述
  1. ::> node run -node <node> sysconfig -a 仅显示一个路径上的磁盘架
slot 0: SAS Host Adapter 0d (Broadcom SAS3616W rev. 2, SAS, <UP>)
    Firmware rev:    12.00.00.00
    NVDATA rev:     12.03.01.02
    Base WWN:      5:00a098:00e41eb:73
    Phy State:      [0] Enabled, 6.0 Gb/s
              [1] Enabled, 6.0 Gb/s
              [2] Enabled, 6.0 Gb/s
              [3] Enabled, 6.0 Gb/s
    Mini-SAS HD Vendor:     OEM
    Mini-SAS HD Part Number:   CAB-Q10/Q10-P1M+01
    Mini-SAS HD Type:      Passive Copper (unequalized) 0.5m end_0
    Mini-SAS HD Serial Number: M200901510002
    30.0 : NETAPP   X426_STBTE1T8A10 NA02 1713.5GB 520B/sect (S3Z0P62K)
    33.23: NETAPP   X426_HCBFE1T8A10 NA05 1713.5GB 520B/sect (08GEATPA)
    Shelf 30: DS2246 Firmware rev. IOM6 A: 0191  IOM6 B: 0191
    Shelf 31: DS2246 Firmware rev. IOM6 A: 0191  IOM6 B: 0200
    Shelf 32: DS2246 Firmware rev. IOM6 A: 0200  IOM6 B: 0200
    Shelf 33: DS2246 Firmware rev. IOM6 A: 0200  IOM6 B: 0200
slot 1: SAS Host Adapter 1c (Broadcom SAS3616W rev. 2, SAS, <UP>)
    Firmware rev:    17.00.00.00
    NVDATA rev:     17.01.00.11
    Base WWN:      5:00605b:01098a9:88
    MFG Part Number:   111-04226
    Board Name:     HBA 9405W-16e
    Assembly:      03-50044-10006
    Serial number:    SPB0521908
    Mini-SAS HD Part Number:   1110683242+00
    Mini-SAS HD Type:      Passive Copper (unequalized) 2m
    Mini-SAS HD Serial Number: M200901510028
  1. 系统存储配置采用多路径HA
NetApp Release 9.7P9: Thu Nov  5 20:15:56 EST 2020
   System ID: 0123456789 (node-01); partner ID: 0987654321 (node-02)
   System Serial Number: 212121212121 (node-01)
   System Rev: B2
   System Storage Configuration: Multi-Path HA
  1. 磁盘架布线最近已更改
New to NetApp?
