跳转到主内容
更换的磁盘未显示绿色 LED
24
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • FAS9000
  • DS2246
问题描述
  • 一个磁盘(例如 53.2sysconfig -a 在更换 AutoSupport 后,此组件中缺少
 53.1: NETAPP X423_HCOBE900A10 NA02 857.0GB 520B/sect (KPGP76GF) 53.3: NETAPP X423_HCOBE900A10 NA02 857.0GB 520B/sect (KPGLRGUF)
  • 虽然磁盘已插入磁盘架,但托架会报告为空(false
Cluster01::> storage shelf show -field bay-id,bay-has-disk,bay-op-status -shelf 15.53 bay-id ------------------------------------------------------------- 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23 bay-has-disk ------------------------------------------------------------------------------------------------------------------------ true,true,false,true,true,true,true,true,true,true,true,true,true,true,true,true,true,true,true,true,true,true,true,true bay-op-status ----------------------------------------------------------------------------------------------------------------------------------------------------------------------- normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,normal,norma
New to NetApp?
