跳转到主内容
"板载:四端口12 G SAS"未显示在sldiag测试输出以及测试系统和压力测试菜单中
26
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
  • FAS8300
  • AF-A400
  • 9.13.1.之前的ONTAP
问题描述
  • 使用SAS连接端口0a-0c、0b-0d。sldiag 输出不包括Onboard: Quad Port 12G SAS"":
Setting LAN IP Address to 192.xxx.xxx.xxx
Setting LAN Subnet Mask to 255.255.255.0
Copyright (c) 2019 NetApp Inc. All rights reserved.
FAS8300 System-Level HW Diagnostics 04.05.09
#### System        PN: xxx-xxxxx                    ####
#### System        SN: xxxxxxxxxxxx                 ####
#### Controller-B  PN: xxx-xxxxx                    ####
#### Controller-B  SN: xxxxxxxxxxxx                 ####
1) Scan System
2) Test System (must scan system, first)
3) Test Memory (must scan system, first)
4) Stress-Test System (must scan system, first)
5) Show VPD Information
6) Show FW Revision
7) Show MAC Address
8) Show Logs
9) Reboot (BMC Power Cycle) Controller to LOADER
Select a number 1-9 to execute the respective command: 1
System Scan Start: 2023-01-23 00:27:55
BMC:
Device ID   Device Rev.   FW Rev.   IPMI Ver.   Device Available
32          1             13.07     2.0         yes
Onboard: Dual Port 25GbE RoCE NIC:
Interface      Link  Speed        FW Version
e0a            Up    25000Mb/s    16.26.4012 (NAP0000000006)
e0b            Up    25000Mb/s    16.26.4012 (NAP0000000006)
Onboard: Dual Port 100GbE RoCE NIC:
e0c            Up    100000Mb/s   16.26.4012 (NAP0000000005)
e0d            Up    100000Mb/s   16.26.4012 (NAP0000000005)
  • Onboard: Quad Port 12G SAS""也不会显示在 Test System 和中 Stress-Test
+--------------------------------Test System-----------------------------------+
| Select one or more items to test using the SPACE bar to toggle the option.   |
| Use Arrow keys to move up/down to select invidiual test. Use Arrow keys      |
| left/right to select Test Control. Press [Enter] to execut.                  |
| |[ ] a. CPU Test                              (Register read test)         | |
| |[ ] b. TPM Test                              (Self-test)                  | |
| |[ ] c. Ethernet I210 Test                    (Internal loopback test)     | |
| |[ ] d. BMC Test                              (Self-test/Sensor status chec| |
| |[ ] e. PSU Test                              (Sensor status check)        | |
| |[ ] f. PCH-I2C Test                          (Device read test)           | |
| |[ ] g. Fan Test                              (Fan speed control test)     | |
| |[ ] h. Onboard: Dual Port 25GbE RoCE NIC Test(BIST/External loopback test)| |
| |[ ] i. Onboard: Dual Port 100GbE RoCE NIC Tes(BIST/External loopback test)| |
| |[ ] j. Mezz: Quad Port 25GbE RoCE NIC Test   (BIST/External loopback test)| |
| |[ ] k. HBA: Dual Port 10GbE NIC Test         (BIST/External loopback test | |
| |[ ] l. HBA: Dual Port 10GbE NIC Test         (BIST/External loopback test | |
<   OK  ><Test all>< Cancel >a(Register read test)
+-----------------------------Stress Test System-------------------------------+
| left/right to select Test Control. Press [Enter] to execut                   |
| |[ ] a. CPU Stress                                 (CPU stress)            | |
| |[ ] b. Memory Stress                              (Random pattern test)   | |
| |[ ] c. M.2 SATA Drive Stress                      (Read operation test)   | |
| |[ ] d. M.2 NVMe Drive Stress                      (Read operation test)   | |
| |[ ] e. Onboard: Dual Port 25GbE RoCE NIC Stress   (External loopback test)| |
| |[ ] f. Onboard: Dual Port 100GbE RoCE NIC Stress  (External loopback test)| |
| |[ ] g. Mezz: Quad Port 25GbE RoCE NIC Stress      (External loopback test)| |
| |[ ] h. HBA: Dual Port 10GbE NIC Stress            (External loopback test)| |
| |[ ] i. HBA: Dual Port 10GbE NIC Stress            (External loopback test)| |
<   OK  ><Test all>< Cancel ><><><><>Press [Enter] key to go back to Main Menu
  • 所有SAS端口均可正常运行、无论是从加载程序还是在启动后检查状态。
New to NetApp?
