跳转到主内容
无法正常接管/交还:合作伙伴缺少文件系统磁盘
177
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • AFF/FAS
问题
  • Command ::> storage failover show 给出:
    Normal giveback not possible:partner missing file system disk
    or
    Normal takeover not possible:partner missing file system disk
  • EMS 事件日志显示几个 cf.disk.inventory.mismatch:error or
cf.disk.inventory.mismatch: Status of the disk e3b.x.x.x (XXXX230:57C22645:00253845:00000002:00000000:00000000:00000000:00000000:00000000:00000000) has recently changed or the node (node-1) is missing the disk.
New to NetApp?
  • 这篇文章对您有帮助吗?
