跳转到主内容
由于 PCIe 模块问题,启动时节点电源循环
86
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF-A70
  • X50133A
问题
  • 节点在启动 ONTAP 时重新启动,出现以下错误:
e3b: port_rcv_data failed.
e3c: port_rcv_data failed.
e3d: port_rcv_data failed.
e3a: port_rcv_data failed.
e3a: ERR: NTAP_power_cycle_after_firmware_dump: fatal error occured with firmware dump collected and will power-cycle to recover...
或
e3a: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3b: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3c: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3d: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3a: ERR: mlx5e_media_change:772:(pid 4954): Query port media capability failed
e3a: ERR: mlx5e_open:4421:(pid 4954): Setting port status to up failed
e3b: ERR: mlx5e_ioctl:4994:(pid 34434): Query module num failed, eeprom reading is not supported
e3c: ERR: mlx5e_ioctl:4994:(pid 34434): Query module num failed, eeprom reading is not supported
e3d: ERR: mlx5e_ioctl:4994:(pid 34434): Query module num failed, eeprom reading is not supported
e3a: ERR: mlx5e_ioctl:4994:(pid 34438): Query module num failed, eeprom reading is not supported
e3b: ERR: mlx5e_ioctl:4994:(pid 39252): Query module num failed, eeprom reading is not supported
e3c: ERR: mlx5e_ioctl:4994:(pid 39252): Query module num failed, eeprom reading is not supported
e3d: ERR: mlx5e_ioctl:4994:(pid 39252): Query module num failed, eeprom reading is not supported
e3a: ERR: mlx5e_ioctl:4994:(pid 39256): Query module num failed, eeprom reading is not supported
e3d: ERR: NTAP_power_cycle_after_firmware_dump: fatal error occured with firmware dump collected and will power-cycle to recover...
  • 重新启动电源并启动 ONTAP 后,插槽 3 上的所有端口将不会联机。
New to NetApp?
