跳转到主内容
节点管理和 SP IP 地址不可访问
178
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS/AFF 系统
  • ONTAP 9
  • 服务处理器 (SP)
问题描述
  • 无法通过 ping/SSH 访问节点管理 IP 和 SP IP。
  • e0M 端口从节点侧显示:
Cluster::> system node run -node <node> -command sysconfig -a
slot 0: Gigabit Ethernet I210
      e0M MAC Address:   d0:39:ea:a0:f9:02 (auto-1000t-fd-up)
  • 在事件日志中发现 e0M 链接在抖动:
[Node-01: mgmt_port_link_status_poll: netif.linkDown:info]: Ethernet Wrench Port: Link down, check cable.
[Node-01: vifmgr: vifmgr.portdown:notice]: A link down event was received on node Node-01, port e0M.
[Node-01: vifmgr: vifmgr.lifmoved.linkdown:notice]: LIF Node-01_mgmt1 (on virtual server 429XXXXX95), IP address 10.XXX.XX.XXX, is being moved to node Node-01, port e0M.
[Node-01: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF Node-01_mgmt1 (on virtual server 429XXXXX95), IP address 10.XXX.XX.XXX, is being removed from node Node-01, port e0M.
[Node-01: mgmt_port_link_status_poll: netif.linkUp:info]: Ethernet Wrench Port: Link up.
[Node-01: vifmgr: vifmgr.portup:notice]: A link up event was received on node Node-01, port e0M.
  • e0M 端口上有一个绿色 LED。但是,连接到 e0M 的交换机端口上没有 LED。
New to NetApp?
