跳转到主内容
AFF-C250 断电后节点缺少合作伙伴磁盘
254
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • NetApp AFF-C250
  • ONTAP 9.13.1P10
问题
  • 在由交流电源断开引起的脏关机后,集群中的 Node 02 无法正常启动,并报告丢失了合作伙伴磁盘。
  • 由于邮箱磁盘状态无效,无法进行存储故障转移。
::> storage failover show
Node       Partner     Takeover Possible State Description
Node1   Node2  true   Connected to Node2. Waiting for cluster applications to come online on the local node.
Node2   -    false   Connected to partner, Partial giveback, Takeover is not possible: Storage failover mailbox disk state is invalid, Local node missing partner disks
2 entries were displayed.
  • Node 02 从 storage failover mailbox-disk show 丢失了一个邮箱磁盘
New to NetApp?
