跳转到主内容
FAS8300/FAS8700/AFF A400 系统上的 NVRAM 电池电量过低警报
429
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF A400
  • FAS8300
  • FAS8700
  • BMC 13.11P1 及更高版本
问题
  • BATTERY (capacity low) 已发送 AutoSupport 邮件。
  • ONTAP 事件消息(EMS-LOG-FILE)示例:
ERROR nvmem.battery.chgrFailed: The NVMEM battery charger is disabled because a bad charger circuit is detected.....
ALERT monitor.shutdown.nvramLowBattery.pending: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
ALERT callhome.battery.low: Call home for BATTERY_LOW.
EMERGENCY monitor.nvramLowBattery: NVRAM battery is dangerously low.
ERROR nvmem.battery.capLowWarn: The NVMEM battery capacity is below normal (4 cycles).
ALERT monitor.shutdown.nvramLowBattery.pending:  NVRAM battery is dangerously low. Halting system in 23 hours. Replace the battery immediately!
  • NVMEM 电池容量低于正常值。示例:
::*> system node environment sensors show -name "Bat Curr"|"Bat Dstg Cycles"
Node Sensor                 State   Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
Node01
     Bat Curr              normal   0 mA        -        -        1225    1475
     Bat Dstg Cycles       warn-low 4 cycles    2        5        -       -
Node02
     Bat Dstg Cycles       normal   14 cycles   2        5        -       -
  • 在 SP-LATEST-STATISTICS AutoSupport 部分中报告的相对电量下降。示例:
Tue Jul 08, 2025 00:27:02 +0530
    RelativeCharge    : 21 %
Tue Jul 08, 2025 13:13:18 +0530
Wed Jul 09, 2025 00:17:03 +0530
    RelativeCharge    : 19 %
Wed Jul 09, 2025 13:13:18 +0530
Thu Jul 10, 2025 00:37:04 +0530
    RelativeCharge    : 18 %
Thu Jul 10, 2025 13:13:18 +0530
  • system battery show 从 BMC 显示:
  • Current 字段显示 0 mA。
  • RelativeCharge 字段显示低于 71%。
  • ChargingCurrent 字段显示 1000 mA。
New to NetApp?
