跳转到主内容
NVMEM 电池在活动学习周期期间发出警报
312
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS2620
  • FAS2750 / FAS2720
  • ONTAP 9
问题
  • EMS 日志中的 node01 上的 NVRAM 电池电量危险地过低。
[node01: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
[node01: statd: monitor.nvramLowBattery.notice:notice]: If the NVRAM battery is dangerously low, the system shuts down automatically every 24 hours to encourage you to replace it. If you reboot the system it will run for another 24 hours before shutting down.
[node01: statd: callhome.battery.low:alert]: Call home for BATTERY_LOW.
[node01: statd: monitor.shutdown.nvramLowBattery.pending:alert]: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
  • 两小时后,SNMP 陷阱 "dhmNoticeDegradedIO" 被发送到客户的监控服务器。
Unsupported Alert,2022/11/02 03:00:12,xxxxxxxx,node01(primary external storage)_tenant 00006100,[failure][node01]dhmNoticeDegradedIO,NNMI_INCIDENT,Run
  • 从 SP 日志中,当时正在执行 NVRAM 电池学习周期。
SP events all
[IPMI.notice]: 7e02 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
[IPMI.notice]: 7f02 | 02 | EVT: 01500005 | Bat_Dstg_Cycles | Assertion Event, "Lower Non-critical going low "
[IPMI.notice]: 8002 | 02 | EVT: 01520002 | Bat_Dstg_Cycles | Assertion Event, "Lower Critical going low "
[IPMI.notice]: 8102 | 02 | EVT: 81520402 | Bat_Dstg_Cycles | Deassertion Event, "Lower Critical going low "
[IPMI.notice]: 8202 | 02 | EVT: 81500d05 | Bat_Dstg_Cycles | Deassertion Event, "Lower Non-critical going low "
[IPMI.notice]: 8302 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
[IPMI.notice]: 8402 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
[IPMI.notice]: 8502 | 02 | EVT: 0300ffff | Bat_Lrn_Active | Assertion Event, "State Deasserted"
SP LATEST IPMI
LrnCycleStartDate : 22-11-01-12:00
LrnCycleStartFCC  : 0x052f
LrnCycleEndFCC   : 0x0347
LrnCycleEndDate   : 22-11-01-18:30
New to NetApp?
