跳转到主内容
NS224 磁盘架无法识别更换的 PSU – “不兼容电源” 警报
23
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用于
  • NetApp AFF-A700
  • ONTAP 9
  • NS224 Disk Shelf
  • PSU 部件号 X737A
问题
  • 在 NS224 磁盘架上更换电源单元 1 (PSU1) 后
  • ONTAP 将新 PSU 报告为“不受支持”并触发持续警报
  • 磁盘架在‘正常’和‘降级’/‘不受支持’状态之间交替
    示例日志输出:
    ALERT ses.psu.comboError: Incompatible power supplies were found on diskshelf "0", serial number: SHJXXXXX000297, productID: NS224NSM100, PSUpartnumbers: PPP-PPPPP+XX, PS-2162-8F.EMERGENCY ses.unsupported.shelf.psu: Shelfid 0 serialnumber SHJHU2216000297 Partnumber PPP-PPPPP+XX not supported on ProductID NS224NSM100.0x: power supply 1.rear of the shelf at the top left.storageshelfshow-power------------------------------------ShelfName: 5.0...PowerSupplyUnits:ID Type Part# Serial# PowerRating ... Firmware Status100 PPP-PPPPP+XX NO_PSN_PRESENT 1600-212 ... 00.06.06 not-supported200 PS-2162-8F 6L8FX010120762G 1600-208 ... 00.06.06 normal...Errors:Critical condition is detected in storage shelf power supply unit "1". The unit might fail.
New to NetApp?
