跳转到主内容
在FAS25xx系统上、多个风扇发生故障并关闭系统
129
Visibility:
Votes:
0
Category:
fas-systems<a>2009年471361</a>
Specialty:
hw
Last Updated:
适用场景
FAS25xx系统
问题描述
  • 系统在启动几分钟后关闭
  • EMS
[node-01:monitor.globalStatus.critical:EMERGENCY]: Controller failover of NSH-FAS-01 is not possible: Controller Failover takeover disabled. Disk shelf fault.
[node-01:monitor.fan.critical:EMERGENCY]: 2 fans have failed. Replace them to avoid overheating. If not corrected, system will shutdown in 2 minutes.
[node-01:callhome.fans.failed:EMERGENCY]: Call home for MULTIPLE FAN FAILURE
[node-01:monitor.globalStatus.critical:EMERGENCY]: Controller failover of NSH-FAS-01 is not possible: Controller Failover takeover disabled. Multiple fans has failed. Power Supply Status Critical: PSU1. Disk shelf fault.
  • 对PSU风扇进行物理检查后、表明其状态为"静止"
New to NetApp?
