跳转到主内容
如何在您的 AFF/FAS 系统上读取 IFSTAT 计数器
792
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
说明
ONTAP 9
命令从每个节点的 Nodeshell 执行
cluster::> system node run -node <node_name> -command ifstat [ -z ] -a | <interface_name>
输出示例
cluster::> system node run -node node_example> -command ifstat e0a
-- interface  e0a  (6 days, 19 hours, 46 minutes, 1 second) --
RECEIVE
 Frames/second:     6  | Bytes/second:    551  | Errors/minute:     0
 Discards/minute:    0  | Total frames:    249k | Total bytes:    19489k
 Total errors:     0  | Total discards:    0  | Multi/broadcast:   235k
 No buffers:      0  | Non-primary u/c:    0  | L2 terminate:     0
 Tag drop:       0  | Vlan tag drop:     0  | Vlan untag drop:    0
 Vlan forwards:     0  | Vlan broadcasts:    0  | Vlan unicasts:     0
 CRC errors:      0  | Alignment errors:   0  | Runt frames:      0
 Long frames:      0  | Fragment:       0  | Jabber:        0
 Xon:          0  | Xoff:         0  | Ring full:       0
 Jumbo:         0  | Jumbo error:      0  | Index error:      0
 Force wakeup:     0
TRANSMIT
 Frames/second:     4  | Bytes/second:    659  | Errors/minute:     0
 Discards/minute:    0  | Total frames:   26386  | Total bytes:    2443k
 Total errors:     0  | Total discards:    0  | Multi/broadcast: 11256
 Queue overflows:    0  | No buffers:      0  | Single collision:   0
 Multi collisions:   0  | Late collisions:    0  | Max collisions:    0
 Deferred:       0  | Xon:          0  | Xoff:         0
 MAC Internal:     0  | Jumbo:         0
LINK_INFO
 Current state:     up | Up to downs:      0  | Speed:       1000m
 Duplex:       full | Flowcontrol:     full
注意:
  • The -z 参数清除统计信息
  • The -a 参数显示所有网络接口的统计信息,包括虚拟主机和环回地址。或者,您可以省略 -a 参数并指定网络接口的名称。
New to NetApp?
