跳转到主内容
AFF-A900 上频繁出现 CHASSIS OVER TEMPERATURE 警报
140
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
适用于
•    AFF-A900
•    网络接口卡 (NIC) X91152A
•    QSFP X6589-R6
问题
  • EMS 日志经常触发 Call Home for CHASSIS OVER TEMPERATURE 警报。
    Tue Mar 31 13:21:31 +0900 [node-01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • 插槽 3 卡上的 e3d 端口及其关联的 VLAN 端口在链路连接和链路关闭状态之间反复循环:
    • 链接启动事件:
      Wed Apr 01 09:57:11 +0900 [node-01: kernel: netif.linkUp:info]: Ethernet e3d: Link up. Wed Apr 01 09:57:11 +0900 [node-01: intr: netif.linkUp:info]: Ethernet e3d-641: Link up.
    • 链接关闭事件:
      Wed Apr 01 09:57:18 +0900 [node-01: kernel: netif.linkDown:info]: Ethernet e3d: Link down, check cable. Wed Apr 01 09:57:18 +0900 [node-01: intr: netif.linkDown:info]: Ethernet e3d-641: Link down, check cable.
    • 未分配给任何广播域的端口:
      Wed Apr 01 09:57:39 +0900 [node-01: vifmgr: vifmgr.reach.unassn:notice]: Network port e3d on node node-01 is not assigned to any broadcast domain. No broadcast domains appear to be reachable from this port. Wed Apr 01 09:57:39 +0900 [node-01: vifmgr: vifmgr.reach.skipped:notice]: Network port e3d on node node-01 was not scanned for reachability because it was administratively or operationally down at the time of the scan.
  • EMS 日志经常显示 chassisTemperature.warm 警报:
    Wed Apr 01 09:58:06 +0900 [node-01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Port temps at max and fans at max speed
  • 在 PLATFORM-SENSORS 中, MLX Highest Temp  的传感器值偶尔显示状态为  crit-high。
    • 传感器输出示例:
      MLX Highest Temp thermal crit-high 85 C 65
New to NetApp?
