跳转到主内容
由于 DomainMismatchFromNodeToShelf_Alert 导致控制器上出现故障 LED
241
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用于
  • NS224 机架
  • 布线
  • DomainMismatchFromNodeToShelf_Alert
问题
  • 控制器上的故障 LED 指示灯亮起
  • 在 EMS 中接收以下警报
[Node-02: schmd: hm.alert.raised:alert]: Alert Id = DomainMismatchFromNodeToShelf_Alert , Alerting Resource = Switch-02(XXXXXXXXXXX) raised by monitor system-connect
[Node-02: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process schm: DomainMismatchFromNodeToShelf_Alert[Switch-02(XXXXXXXXXXX)].
  • 已观察到健康警报
Cluster::> system health alert show
               Node: Node-02
           Alert ID: DomainMismatchFromNodeToShelf_Alert
           Resource: Switch name: Switch-02(XXXXXXXXXXXX)
           Severity: Major
    Indication Time: Sat Apr 02 16:24:02 2022
           Suppress: false
        Acknowledge: false
     Probable Cause: The storage domain between the nodes Node-01,
                     Node-02 and switch Switch-02 is different
                     from the domain between the switch and shelves 3.1,
                     3.2.
    Possible Effect: This issue will affect conversions to direct-attached
                     storage.
Corrective Actions: Connect the switch Switch-02 to both the node and
                     the shelves with the same storage domain, following
                     the guide applicable to your shelf.
New to NetApp?
