FCP 适配器在 EMS 中报告"scsitarget.hwpfct.mserr"错误,原因代码为 0x9,响应代码为 0x8001
适用于
- ONTAP 9
- FAS 系列
问题
EMS 日志显示 scsitarget.hwpfct.mserr 错误,原因代码为 0x9 和响应代码 0x8001
示例:
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001.
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0f failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001.
[Node-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GA_NXT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0x1 (Port id not registered), and response code 0x8001.
