跳转到主内容
FAS9000 NVRAM电池容量严重不足(0个周期)警告
376
Visibility:
Votes:
0
Category:
fas-systems<a>FAS9000</a><a>电池</a><a>1335880</a>
Specialty:
hw
Last Updated:
适用场景
  • AFF A700/FAS9000
  • 低于4.9的服务处理器(SP)固件
问题描述
NVRAM电池容量严重不足(0个周期)警告并会尽快恢复。
示例:
Sun Sep 06 00:00:31 CST [host1: env_mgr: nvram.battery.capacity.low.critical:EMERGENCY]: The NVRAM battery capacity is critically low (0 cycles). To prevent data loss, the system will shut down in 5 minutes.
Sun Sep 06 00:01:12 CST [host1: env_mgr: nvram.battery.capacity.normal:info]: The NVRAM battery capacity is normal.
Sun Sep 06 00:01:32 CST [host1: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
New to NetApp?
