FAS8300/FAS8700/A400主板更换0磁盘未找到根卷
适用场景
- FAS8300
- FAS8700
- AFF A400
- ONTAP 9.13.1.
- 如何在更换部件期间进行故障排除的所有步骤都会收到消息"警告: 似乎没有任何磁盘连接到系统" 已通过验证、包括:
- e0a/e0b已为HA互连正确布线
- HA配对节点已完成接管
- 已在维护模式下正确检测到已关闭节点的所有磁盘
问题描述
- 节点未启动至""
Waiting for giveback...
状态 - 磁盘自动重新分配失败、新主板进入启动循环:
- 节点未启动至""
Dec 30 10:44:24 [CLUSTER-02:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
Dec 30 10:44:24 [CLUSTER-02:raid.assim.tree.noRootVol:error]: No usable root volume was found!
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
8 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Select option 4 from the boot menu to choose disks for the root volume and spare core space.
Target Adapters found:
4 Fibre Channel Target Adapters found!
0 iSCSI Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
