跳转到主内容
FAS2820 无法启动系统级诊断
98
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用于
  • NetApp FAS2820
  • ONTAP 9
  • 连接了外部 SAS 磁盘架的的系统
问题
  • 在初始设置或硬件维护期间尝试启动系统级诊断时,如果连接了 SAS 磁盘架电缆,则诊断模式将无法启动。观察到以下日志输出:
LOADER-A> boot_diags
Wait for driver loading...
[73.264215] sas: TMF task timeout for 5000c500f5897afe and not done
[114.736221] sas: TMF task timeout for 5000c500f5897afe and not done
[156.208223] sas: TMF task timeout for 5000c500f5897afe and not done
[197.680218] sas: TMF task timeout for 5000c500f5897afe and not done
[197.686648] pm80xx: rc=-5
* Loading driver timeout! ENV setup may be incomplete!! *
ls: cannot access '/sys/class/sas_phy/phy-6:4/device/port/': No such file or directory
[402.857729] Midplane not recognized after 5 retries!
  • 系统可能会崩溃并直接重新启动 ONTAP。
[   36.140140] Kernel panic - not syncing: Fatal exception in interrupt
[   36.372966] Kernel Offset: disabled
[   36.573955] Rebooting in 60 seconds..
  • 只有在断开 SAS 电缆连接后,才能成功启动诊断模式。
New to NetApp?
