跳转到主内容
FAS2554 警示 LED 亮起
192
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • FAS2554
  • 7-模式 Data ONTAP
  • 服务处理器( SP )固件 2.2.5P2
问题描述
  • 控制器警示 LED 亮起
  • ONTAP 命令 storage show fault -v 会报告状态正常,但所有 PSU 均具有 DC UNDER VOLTAGE
node_name> storage show fault -v
Enclosure Status: normal
Channel: 0a
Shelf: 0
Shelf Type: DS4246
Product Serial Number: serial_number
Module Type: IOM6E
Power Supplies:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,00,04,A0   DC UNDER VOLTAGE, RQSTED ON
  2: OK                01,00,04,A0   DC UNDER VOLTAGE, RQSTED ON
  3: OK                01,00,04,A0   DC UNDER VOLTAGE, RQSTED ON
  4: OK                01,00,04,A0   DC UNDER VOLTAGE, RQSTED ON
New to NetApp?
