断电后延迟过长
适用场景
- FAS2750
- ONTAP 9.7P3
- 断电
问题描述
- 发生导致两个节点重新启动的断电后、系统上会出现过多延迟
- 集群出现高延迟
Workload ID Latency Network Cluster Data Disk QoS Max QoS Min NVRAM
volume1 17347 36.05ms 106.00us 35.09ms 641.00us 5.09ms 0ms 0ms 25.00us
volume2 20282 34.12ms 90.00us 33.41ms 420.00us 3.41ms 0ms 0ms 11.00us
- 其中一个控制器集群端口显示多个CRC和符号错误
-- interface e0b (0 hours, 10 minutes, 30 seconds) -- RECEIVE Total frames: 839k | Frames/second: 1332 | Total bytes: 3980m Bytes/second: 6318k | Total errors: 20924 | Errors/minute: 1993 Total discards: 0 | Discards/minute: 0 | Multi/broadcast: 50 Non-primary u/c: 0 | CRC errors: 20877 | Runt frames: 0 Fragment: 0 | Long frames: 0 | Jabber: 45 Length errors: 2 | No buffer: 0 | Xon: 0 Xoff: 0 | Pause: 0 | Jumbo: 483k Noproto: 0 | Error symbol: 319 | Illegal symbol: 66 Bus overruns: 0 | Queue drops: 0 | LRO segments: 571k LRO bytes: 3925m | LRO6 segments: 0 | LRO6 bytes: 0 Bad UDP cksum: 0 | Bad UDP6 cksum: 0 | Bad TCP cksum: 0 Bad TCP6 cksum: 0 | Mcast v6 solicit: 0 | Lagg errors: 0 Lacp errors: 0 | Lacp PDU errors: 0
