在ONTAP 升级期间、无法访问数据
适用场景
- AFF A400
- ONTAP 9
问题描述
系统无法交还、并显示以下错误:
cluster1::> storage failover giveback -ofnode node1
Error: command failed: Failed to initiate giveback. Reason: HA partner RAID or WAFL label versions are older than this node's labels.
Run the "system node image show" command to determine which image on the partner should be booted to be compatible with the local node.Firmware update complete. System rebooting...
?[m?[2J?[HBIOS Version: 16.7
PEI start.
CPU PEI initialization.
Wait BMC self-test result.
BMC self-test: OK.
UPI initialization.
CPU initialization.
Running full memory initialization.
CPU reset.Boot Loader version 6.4.13
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2022 NetApp, Inc. All Rights Reserved.
ACPI RSDP Found at 0x6c9eb000
Starting AUTOBOOT press Ctrl-C to abort...
Loading X86_64/freebsd/image2/kernel:0x200000/1135184 0x316000/11672328 0x1038000/3929800 0x13f76c8/13421024 0x200240/1016 Entry at 0xffffffff80316000
Loading X86_64/freebsd/image2/platform.ko:0x20c5000/4751408 0x254d030/615264
Starting program at 0xffffffff80316000
NetApp Data ONTAP 9.8P9
ena_rss_init_default_deferred() [TID:100000]: No devclass ena
IPMI device unit 0 rev. 1, firmware rev. 13.06, version 2.0, device support mask 0xbf
IPMI device unit 1 rev. 1, firmware rev. 13.06, version 2.0, device support mask 0xbf
Fri Dec 2 11:52:24 2022 [nvdimm.nvmem.destage.succeed:NOTICE]:NVMEM subsystem successfully copied nonvolatile data to flash memory on NVDIMM device in 65 seconds.
Fri Dec 2 11:52:24 2022 [nvdimm.nvmem.restage.succeed:NOTICE]:NVMEM subsystem successfully restored nonvolatile data from flash memory on NVDIMM device in 68 seconds.
Copyright (C) 1992-2021 NetApp.
All rights reserved.
* Press Ctrl-C for Boot Menu. *
Warning: A clean shutdown did not occur and the default boot
image was not modified. To change the default boot image,
the operation must be followed by a clean shutdown.
[?] Fri Dec 02 22:57:36 +1100 [Node1: send_boot_msg_thread: mgr.boot.reason_abnormal:EMERGENCY]: System rebooted after a panic.
