在sysconfig-A中检测到磁盘、但在sysconfig-r中检测到磁盘在更换后失败
适用场景
- Data ONTAP 8 7-模式
- 磁盘资格审批包( DKP )
问题描述
- 磁盘出现故障并已更换。在 sysconfig -a输出中列出。示例:
3.14: NETAPP   X318_HARHE08TA07 NA00 7486.1GB 520B/sect (VKJ1M9PX)
- 更换的磁盘将作为备用磁盘列出、而不会在RAID组中进行更换。示例:
Pool0 spare disks
     RAID Disk   Device    HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)   Phys (MB/blks)
    spare     0b.03.14  0b   3   14  SA:B   0   SAS 15000 7486157/15331651072 7501160/15362376264
Aggregate aggr4 (online, raid_dp, degraded) (block checksums)
     Plex /aggr4/plex0 (online, normal, active)
       RAID group /aggr4/plex0/rg0 (normal, block checksums)
      RAID group /aggr4/plex0/rg1 (degraded, block checksums)
        parity   0b.03.13   0b   3   13  SA:B   0  FSAS  7200 7486157/15331651072 7501160/15362376264
       data    FAILED       N/A             7486157/ -
        data    0b.03.15   0b   3   15  SA:B   0  FSAS  7200 7486157/15331651072
- DQP已过时或未安装。示例:
Disk Qualification Package Details:
     Package Date:  Unable to load any package (Package version not supported)
    Header Information
       FileName   = N/A
      FileVersion = N/A
      DriveRecordCount = N/A
      AliasRecordCount = N/A
      DeviceRecordCount = N/A
      SystemRecordCount = N/A
