由于电缆未正确插入,导致发生降级联机Port_Alert
适用场景
- ONTAP 9
- FAS/AFA
问题描述
- 节点的故障 LED亮起。
- EMS报告
DegradedOnlinePort_Alert
[?] Mon Jan 01 04:01:49 +0000 [Node: pmcsas_timeout_0: sas.cable.degraded:error]: Cable attached to SAS port "1d" is functioning in a degraded mode.[?] Mon Jan 01 04:02:14 +0000 [Node: nchmd: hm.alert.raised:alert]: Alert Id = DegradedOnlinePort_Alert , Alerting Resource = 1d raised by monitor node-connect[?] Mon Jan 01 04:04:02 +0000 [Node: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process nchm: DegradedOnlinePort_Alert[1d].- 中已禁用物理
SYSCONFIG-A
slot 1: SAS Host Adapter 1d (PMC-Sierra PM8072 rev. C, SAS, <UP>)MFG Part Number: Microsemi Corp. 110-03801 rev. A0Part number: 111-03801+A0Serial number: XXXXXXXXXXXDate Code: 20180706Firmware rev: 03.08.09.00Base WWN: 5:0000d1:7048bcc:0cTemperature: 38 CPhy State: [4] Enabled, 12.0 Gb/s [5] Disabled [6] Enabled, 12.0 Gb/s [7] Enabled, 12.0 Gb/s
