跳转到主内容
已为打开的抽屉报告 DS460 货架故障
155
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
适用于
  • ONTAP 9
  • DS460
问题描述
  • Storage show fault 显示磁盘架状态为严重
    ::> node run -node <NodeName> storage show fault Enclosure Status: critical Channel: 1b Shelf: 54
  • 在相同的输出中,其中一个抽屉显示打开
    Drawers Control Module:
    Element Status                      Status Bytes  Status Descriptions
      1 [IOM12 A]    : OK                01,00,01,00   REPORT
      2 [IOM12 A]    : OK                01,00,01,00   REPORT
      3 [IOM12 A]    : OK                01,00,01,00   REPORT
      4: NOT INSTALLED     05,40,00,00
      5 [IOM12 A]    : OK                01,00,01,00 REPORT
      6 [IOM12 B]    : OK                01,00,01,00   REPORT
      7 [IOM12 B]    : OK                01,00,01,00   REPORT
      8 [IOM12 B]    : OK                01,00,01,00   REPORT
      9 [IOM12 B]    : OK                01,00,01,00   REPORT
     10 [IOM12 B]    : OK                01,00,01,00   REPORT
  • 驱动器或 IOM 可能有其他警报
  • 这会导致在自动支持中调用磁盘冗余警报
    HA Group Notification (DISK REDUNDANCY FAILED) ERROR
New to NetApp?
